| AM Only - No FM or Cassette | |
| Tweet Topic Started: Apr 14 2018, 08:53 PM (252 Views) | |
| Michigan Sportsman | Apr 14 2018, 08:53 PM Post #1 |
1995 Hatchback I insert a cassette and it spits it out. I select FM and no sound on any channel selection. I select AM and all is well on any station. No error codes. No LOC code. Any suggestions? |
| PTA2PTB | Apr 14 2018, 09:07 PM Post #2 |
Slap an NPR bumper sticker on the back of it?
| Michigan Sportsman | Apr 14 2018, 09:17 PM Post #3 |
Why didn’t I think of that!
| Swifterthanu | Apr 14 2018, 09:22 PM Post #4 |
Teamswift troller
| MR1 Kingsbury | Apr 14 2018, 10:00 PM Post #5 |
Exp. builder/rebuilder
radio antenna.... IF it won't keep a cassette in, it could be a funny metal tang that isn't positioning proper to hold it right and it instantly ejects. never had one of these apart to fix the cassette thing, but i have 2 of them that do the same thing Edited by MR1 Kingsbury, Apr 14 2018, 10:02 PM.
| Metromightymouse | Apr 14 2018, 11:05 PM Post #6 |
The radio doesn't work? You way overpaid for it then... |
| Michigan Sportsman | Apr 15 2018, 12:10 AM Post #7 |
Antenna... Ok maybe the connection is disconnected to the back of the radio. I’ll start there. Thanks MR1
| Michigan Sportsman | Apr 15 2018, 12:42 AM Post #8 |
Yeah, there are a couple things I need to fix, but it is one of those things that I had to have. I owned a ratty 1990 metro that I drove many years ago when I was young and poor as dirt and have always said it was the best and funnest car I ever owned. I was willing to pay more and will be enjoying it and fixing it for a long time, God willing. The way I see it, that car will pay for itself within two summers with fuel, plates, and insurance savings.
| sphenicie | Apr 15 2018, 06:21 AM Post #9 |
To bad you are not in the UP! 55,000 miles? Original? Wow, how do the frame horns look? |
| Michigan Sportsman | Apr 15 2018, 09:28 AM Post #10 |
I’m not sure what frame horns are, but I saw nothing but original painted surfaces without rust throughout. I plan on protecting all the metal surfaces I can with epoxy paint and/or undercoating mixed with unicorn piss or something... I haven’t quite figured it out yet, I’m still researching/learning
| WiscoMetro | Apr 15 2018, 10:08 AM Post #11 |
Seeking the Science of MPG
![]() That it what you are looking for .Hope for it looking more like this:
| Michigan Sportsman | Apr 15 2018, 01:36 PM Post #12 |
Thanks for the pics, now I know. No luck uploading a pic, but my Geo has only painted surface and no rust. If I look really close there may be a trace of rust at the seam. I plan to remove that with maybe a sand blaster and then a trillion coats of epoxy paint. I may also consider lubricating it from the inside using lanolin based Flex Film via a small access hole and a special flex spray nozzle. |
7:54 PM Jul 10
