Flange bolts
Topic Started: May 13 2018, 07:06 PM (197 Views)
blue_can
Anyone know where to get these. The threads on both the nuts and bolts are in bad shape. I managed to clean up the threads on the nuts and I'm going to try and do the same for the bolts. In the even this does not work I need to find a replacement.
I suppose I could use a regular flange bolt without the serrated surround but would be good to get the original type.
The threads are M10 X 1.25
Attached to this post:
Attachments: 20180513_165331__600x338_.jpg (133.12 KB)
freegeo
I can't think of where those bolts are used on the car. Where did you get them off of? Most places that sell hardware usually have a flange type bolt. Not seen one like that, that had a serrated area too. If I know where it came off of I might be able to get a part number for you.
Edited by freegeo, May 13 2018, 07:20 PM.
blue_can
freegeo
May 13 2018, 07:19 PM
It in the place marked by the red lines in the attached GM parts diagram. From the diagram it looks like the entire muffler/resonator/ pipe assembly comes with these bolts in place so it may be that they cannot be obtained as a separate part.
Not too keen to spend $$ on an entire assembly (which is available new online from GM parts places) just because of these bolts especially since the rest of it is in very good condition.
Due to the state of the bolts I cannot get a good seal on that joint.
Attachments: 980604SU03_086.jpg (114.72 KB)
freegeo
Thanks for the diagram. That helps. I'm not sure you could get the same exact bolt. I would just get a new flange bolt or bolt with a good washer and nut to replace it with. I will look to see if that has a separate part number though.
freegeo
Those bolts are part on the flange and don't come separate.
blue_can
OK thanks. I will try and clean up the existing bolts with a die - if that does not work I will use a regular flange bolt or a bolt with a washer as suggested.
freegeo
There is only one place that might have a bolt like that. Fastenal. https://www.fastenal.com/
geogonfa
Just my .02¢... :type
I generally just install some stainless steel nuts and bolts in place of those with a few washers...
Stiffchezze
Sir Metrologist
geogonfa
May 13 2018, 09:36 PM
:+1
suzukitom
Tom
lock washers... and a dab of anti seize
sphenicie
geogonfa
Plus 2.
SS 3/8" bolts, cheap, easy......DONE.
blue_can
OK thanks for the input everyone. I tried to repair the threads on the bolts with a rethreading die - it partially worked but the threads at the start were too damaged and I could not get the bolt to start threading even though the rest of the threads were repaired okay.
So I installed new bolts as suggested.
I'm curious as to how they made these bolts. Maybe they used custom tooling - maybe a standard bolt which was pressed through a die to create the serrations and then maybe pressed on the exhaust flange to cutout the corresponding pattern there - or the flange also pressed out using some form of die.
