Turning A/C on shuts the engine off at idle
Topic Started: May 30 2018, 06:28 PM (155 Views)
YellaSwift
Would anyone happen to know, on a 1990 3cyl/5spd what would compensate the idle speed when the A/C is turned on. In order for it to work, I have to be driving or holding the gas down. Thanks in a advance.
nineoneandblue
There is an idle adjustment for the a/c, near the firewall center. Find the FSM posted here on the forum for more specifics.
Here's a link ..... scrool down about 10 pics in.
Edited by nineoneandblue, May 30 2018, 06:51 PM.
suzukitom
Tom
read this post on adjusting your VSV.
http://geometroforum.com/single/?p=1005154&t=5831211
It's supposed to idle up, but might not nearly thirty years down the road.
Also, if your engine is weak the idle up might not be enough.
Edited by Woodie, Jun 1 2018, 05:48 AM.
geogonfa
Just my .02ยข...When was the last time the engine has had a compression test done?
If it's been awhile start here, because this will help us in diagnosing your problem;
http://geometroforum.com/topic/2574993/1/
:type
nwgeo
AC control module may be bad. AC coolant temperature sensor may be bad.
MR1 Kingsbury
Exp. builder/rebuilder
there is a capacitor (group) taped into the wiring harness, that 'directs' the idle up signal when the rwd, heater/blower, or headlights are energized. On my 96 it is taped into the harness behind the radio. hard to notice unless you looking for a bulge in the already factory taped up wiring cluster heading to the PCM.
Like many 25 year old capacitors, they are likely to fail and will not message the pcm/ecm to up the idle.
I do agree that a compression test is in order, and a cleaning and testing evaluation of your IAC.
