Revival and continuation of 2015 metro alternator bike post
Topic Started: Jul 12 2018, 05:37 AM (115 Views)
geopanda2
http://geometroforum.com/topic/5880515/1/
So back a couple years ago i had the idea i was going to make a geo metro bike generator to charge a 12v battery / battery bank / small inverter. Yes i know very well and expect very little power from it. Ive set the gearing and diameters of pulleys to reach proper rpms for charging. But now need a little guidance on the tabs in the back of the alternator. I believe one tab is for ignition on and would recieve 12v via an on off switch so i could turn it on once i get it to speed. I believe one tab is for lamp ground and am not sure what to do with it. I hear the 3rd tab may or not be a dummy tab or ground. Any help would be greatly appreciated. Also would this be how i wire said device?
geopanda2
So after some testing top left is ignition, top right is lamp and bottom is ground, i got it to work set up on a workbench but hooked up to the bike it did not work : (
91 ragtop
Maybe because you're turning it backwards from what it turns on a Metro.
Ken.....
MR1 Kingsbury
Exp. builder/rebuilder
Good Eye, Ken... I think that'd be backwards for almost all alternators on vehicles today. Most all starters also turn clockwise as viewed from the business end.
Edited by MR1 Kingsbury, Jul 12 2018, 09:21 PM.
David95237
It doesn't make any difference what way an alternator turns. Probably going to slow.
geopanda2
:0 something i did not think about , off the bike it was spinning clockwise and on the bike its mounted to spin counterclockwise. I figured spinning was spinning but perhaps not.
