Strut mount brands...
Topic Started: Aug 1 2018, 06:34 PM (85 Views)
Dirty_Dan
I'm replacing the all the stock struts on my 94 metro with kyb's and I purchased two of these strut mount rebuild kits off ebay. My front strut mounts also look cracked and worn so I was going to replace them. I found these relatively cheap mounts on amazon and was wondering if anyone had any experience with them or other brands. The name brand ones like KYB and Monroe cost $30-50 each vs $15 for these, but I'm not sure if there's a big difference in quality.
Any help would be appreciated! :)
geogonfa
First...
Welcome to the Fun... :greet
Now...
Just my .02ยข
These have worked well so far for the mount:
https://www.amazon.com/KYB-SM5188-Strut-Mount-Kit/dp/B000C44DIO/ref=sr_1_1?ie=UTF8&qid=1533171227&sr=8-1&keywords=KYB+SM5188
These have worked for a replacement for the bearing assembly because it is one piece and sealed, but, the original lasted for years (the set you posted from bowens), so either way:
https://www.amazon.com/gp/product/B00CUEBYH2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
t3ragtop
I have found that the KYB struts mounts work fine, some of the other cheaper brands I have used seem to crack/ tear prematurely. ;)
I try to keep a couple of the strut bearing kits from bbowens on hand for rebuilding struts.
Just a reminder, remember to use the big flat washer on the bottoms of the rear mounts.
Dirty_Dan
Just wanted to say thanks for the help! I ended up ordering a set of kyb mounts. Last week I did the rear shocks and it went well, now I'm starting on the front struts.
Should be a big improvement!
