| 97 Metro 1.0 Oil Leak Pic included; Oil Leak | |
| Topic Started: Dec 16 2008, 09:01 PM (552 Views) | |
| Shane269 | Dec 16 2008, 09:01 PM Post #1 |
I have a 1997 Metro that have an oil leak but I am stumped at what would cause it. I cleaned the area with brake cleaner then drove it 30 miles when I got home I took this picture. I have marked where the fresh oil has showed up. I was all clean to start with. There is also a shadow look that is oil running down the side of the transmission. Is the Motor oil leaking from that clutch shaft on the top of the transmission? I would have thought it would be much thicker than motor oil. Thanks for your help! Shane ![]() Edited by Shane269, Dec 16 2008, 09:03 PM.
| Johnny Mullet | Dec 16 2008, 09:11 PM Post #2 |
"Geo Whisperer"
First we have to determine if it's engine oil or trans fluid. Start by removing the distributor cap and see if there is any oil in there. Then check the distributor O-ring where it inserts into the side of the head. Also check all areas above the oily area like the valve cover gasket. |
| bonjoey | Dec 16 2008, 09:25 PM Post #3 |
hey, mine got the same leak, after 5000kms, no loss on engine oil. i haven't checked it yet if its engine oil, trans fluid or brake/clutch fluid. |
| rr87 | Dec 16 2008, 09:53 PM Post #4 |
50 MPG!
damn I should get my car checked, I have a major oil leak
| metromad | Dec 16 2008, 10:24 PM Post #5 |
Moderator
Follow JM's advice above about the distributor. That is definitely and indication of an oil leak at the dist. If there is oil inside the cap, I can walk you through the repair. If there is none inside but a drop of oil on the base flange of the dist. just below the bottom timing adjust bolt, then you have a leaky dist. "o"ring seal. This is the easiest to repair, just remove the "o" ring and take it to your closest auto parts store and match it up to one they have. Re-install "o" ring, re-install dist. No sweat.
Edited by metromad, Dec 16 2008, 10:24 PM.
| metroschultz | Dec 16 2008, 11:54 PM Post #6 |
NHRA N E 1
I vote distributor also. Looks like it is dripping from the cap to the clutch release lever. S. |
| rr87 | Dec 17 2008, 12:39 AM Post #7 |
50 MPG!
My oil leak is so bad I have to put 2 quarts in 1.000 miles! Should I take my car to a mechanic ASAP or should I take my time and try to fix it at home with friend's help?
| Will | Dec 17 2008, 06:11 AM Post #8 |
Victory is mine!!!!
Where is it leaking from?
| metromad | Dec 17 2008, 01:31 PM Post #9 |
Moderator
Sounds like your camshaft seal or front crank seal might be leaking. Let us know where you see the most fresh oil. Either one of those is doable on your own in a couple of hours.
| pacapo | Dec 17 2008, 02:06 PM Post #10 |
Over 50 Years of Wrenching Experience...
The distributor O-ring is Dorman part # 64213 You can buy them from the Kragen Auto Parts chain. A 5 pack is around $3.00 |
| Shane269 | Dec 17 2008, 02:58 PM Post #11 |
Thanks everyone for the help. Sure enough the bottom timing adjusting bolt is wet with oil. So what is the process to change that O-ring? |
| Shane269 | Dec 17 2008, 07:25 PM Post #12 |
To change this O-ring are these the steps? 1. Remove distributer cap. 2. Mark the rotor at TDC #1 3. Remove two timing adjusting screws. 4. Wiggle the distributer loose from the engine. 5. Remove and replace O-ring. (Does the O-Ring get lubed for installation?) 6. Replace all items in reverse order. Am I missing something? Is this the part for the repair? "The distributor O-ring is Dorman part # 64213" Thanks pacapo! |
| rr87 | Dec 17 2008, 11:17 PM Post #13 |
50 MPG!
I cleaned the engine a bit today...here are 15 pics. I will take more pics on friday so we notice how bad it will look by then. I hope some of you guys can notice something with the pictures I'm uploading right now, in advance I thank you all for trying to help. |
| 99metro | Dec 18 2008, 08:07 AM Post #14 |
putt-putt
I was thinking that it was coming from the distributor/cam. I wish the top of MY tranny looked so clean! I won't post a picture of it - it will make you lose your lunch. |
| pacapo | Dec 23 2008, 12:51 PM Post #15 |
rr87 has a valve cover gasket leak as well as a distributor O-ring leak. The 4 'washers' under the castle nuts need to be tightened a little. Or, you'll have to swap out the gasket. The oil pan was put on with the old Permatex Orange. You should never use that. I stopped using that when Permatex Ultra Black came out. Get some Permatex Ultra Gray, pull that pan and put a paper thin coat on the block and the pan. Also your front main oil seal and cam seal are probably leaking. Better plan on getting some parts for that engine and redoing it in the Spring. The Metro I did a couple of months ago is identical, and you can sleep under it without a drop of oil anywhere. That tells me it's a well designed engine, once you get it back up to snuff. |
5:06 PM Jul 30
